Community maintained
Desktop
Armbian 26.8.0-trunk.170 XFCE
Kernel: 6.18.35, Size: 815.3 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Kernel: 6.18.35, Size: 296.1 MB, Release date: Jun 24, 2026
Rockchip RK3399
