orangepi3
Community maintained
Desktop
Armbian 26.8.0-trunk.170 XFCE
Kernel: 6.18.35, Size: 772 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Kernel: 6.18.35, Size: 265.5 MB, Release date: Jun 24, 2026
  • PCIe port is not supported: Allwinner H6 has a quirky PCIe controller that doesn’t map the PCIe address space properly to CPU, and accessing the PCIe config space, IO space or memory space will need to be wrapped. As Linux doesn’t wrap PCIe memory space access, it’s not possible to do a proper PCIe controller driver for H6. The BSP kernel modifies the driver to wrap the access, so it’s also not generic, and only devices with modified driver will work. Armbian does not support BSP based kernels. You can find more information here and here.
1000tx 1wire 2GB 4 core 64bit UASP bluetooth docker eMMC i2c spi spi flash usb3 wifi wireguard Allwinner H6
Armbian images and kernels can be made from scratch. Supported environment for build framework is any any X64 based Linux distribution. You can re-make live bootable image or just a kernel+dtb(hardware configuration) package which you transfer to your image and install with: dpkg -i linux-image-[branch]-family.deb linux-dtb-[branch]-family.deb. In that process you can enforce many customisation.
