Standard support
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.18.8, Size: 300.3 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Stable user space packages
  • Images for non LTS version can be downloaded here
Ubuntu Noble 24.8.1 XFCE testing:
  • Boot ok, from both sdcard and emmc
  • HDMI ok, boot splash screen shows up
  • USB2 and USB3 ok
  • Gigabit ethernet ok
  • Wireless ok
  • Bluetooth ok (although a bit spotty and usual cohabitation issues with wifi)
  • Analog audio codec is ok
  • Reboot and shutdown work as intended
 Debian Bookworm 24.8.1 minimal testing:
  • HDMI ok
  • USB2 and USB3 ok
  • Gigabit ethernet ok, throughput is fine (~960mbps)
  • Wireless ok, throughput ok (~50mbps at 2.4ghz, but far from router)
Build Date: Jun 24, 2026
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.1 GB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 293.5 MB
Resolute Minimal / IOT SHA    ASC 292.8 MB
Debian Testing (Sid) Kali Linux SHA    ASC 574.5 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 576 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 429.6 MB
1000tx 4GB 6 core UASP bluetooth docker eMMC i2c pci usb-c usb3 wifi wireguard Rockchip RK3399
Debian 14 (Forky) Minimal / IOT rolling 6.18.36 SHA  ASC 319.4 MB
Resolute XFCE stable 6.18.36 SHA  ASC 813.3 MB
