orangepilite2
Community maintained
Desktop
Armbian 26.8.0-trunk.170 XFCE
Kernel: 6.18.35, Size: 752.3 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Kernel: 6.18.35, Size: 263.1 MB, Release date: Jun 24, 2026
  • USB3 sometimes doesn’t detect high-speed devices properly
  • A heat sink is highly recommended if you want to run it at full speed
  • Changing screen resolution
4 core 64bit UASP bluetooth docker spi usb3 wifi wireguard Allwinner H6
