orangepioneplus
Community maintained
Desktop
Armbian 26.8.0-trunk.170 XFCE
Kernel: 6.18.35, Size: 782.3 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Kernel: 6.18.35, Size: 279.7 MB, Release date: Jun 24, 2026
  • USB3 sometimes doesn’t detect high-speed devices properly
1000tx 1wire 4 core 64bit UASP docker i2c i2s spi wireguard Allwinner H6
