orangepizero3
Community maintained
Desktop
Armbian 26.8.0-trunk.170 XFCE
Kernel: 6.18.35, Size: 758.7 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Kernel: 6.18.35, Size: 267.4 MB, Release date: Jun 24, 2026
The 26 pin headers on Orange Pi Zero3 provides the following interfaces:-
  • 3 I2C
  • 2 UARTS
  • 2 PWM
  • 1 SPDIF
  • 1 I2S
  • and 1 SPI with 2 CS pins.
The pwm, spdif and i2s support is not there in kernel yet and hence overlays for them are not yet available. We have added overlays for i2c and uart. The spidev1_0 and spidev1_1 needs some editing and will be fixed in the future. When using the overlays, user should make sure they don’t enable overlay for features that use the same pin as this can cause conflict and either only one of the conflicting overlays or none of conflicting overlays will work. Its easy to fix it though as one can just disable it again from armbian-config.
Build Date: Jun 24, 2026
Debian 12 (Bookworm) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 481.5 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 241.1 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 239.5 MB
Allwinner H616
