- Images for non LTS version can be downloaded here
Build Date: Jun 24, 2026
| Kali Linux | SHA | ASC | 551 MB | |||||||
| Home Assistant | SHA | ASC | 543.7 MB | |||||||
| OpenMediaVault | SHA | ASC | 398.8 MB | |||||||
| OpenHab | SHA | ASC | 1.2 GB | |||||||
1000tx 1wire 2GB 4 core 64bit UASP bluetooth docker eMMC i2c spi spi flash usb-c usb3 wifi wireguard Allwinner H6
- join community forums
| Minimal / IOT | rolling | 6.18.36 | SHA | ASC | 285.8 MB | ||
| Resolute | XFCE | stable | 6.18.36 | SHA | ASC | 763.9 MB | |
