orangepi-5plus
Standard support
Desktop
Armbian 26.5.1 Gnome
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.5.1 Minimal / IOT
Kernel: 6.1.115, Size: 292.7 MB, Release date: Jun 24, 2026
Build Date: Jun 24, 2026
Resolute Minimal / IOT SHA    ASC 318 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 317.1 MB
Resolute Minimal / IOT SHA    ASC 289.8 MB
Debian Testing (Sid) Kali Linux SHA    ASC 543.4 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 533.2 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 383.8 MB
Rockchip RK3588
Debian 14 (Forky) Minimal / IOT rolling 6.1.115 SHA  ASC 279.6 MB
Resolute Gnome stable 6.1.115 SHA  ASC 969.3 MB
