orangepi5pro
Community maintained
Desktop
Armbian 26.8.0-trunk.170 Gnome
Kernel: 6.1.115, Size: 957.4 MB, Release date: Jun 24, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Kernel: 6.1.115, Size: 280.4 MB, Release date: Jun 24, 2026
PCI support is broken on vendor kernel (6.1.xx) on versions higher then 24.8.1. Use this version and freeze kernel (armbian-config -> system) prior to updating OS. PCI works on other Rockchip 3588 devices, while fixing this on all represent expensive technical challenge which we will be able to proceed once your donations for entire project reaches at least 1000 USD per month. With Orangepi devices we have extremely high negative support budget. Alternative operating systems that relies on our work face the same problem. We appreciate for your understanding.
Build Date: Jun 24, 2026
Resolute Gnome SHA    ASC 979.1 MB
Resolute KDE Plasma SHA    ASC 1.3 GB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 319.3 MB
RK3588 Rockchip
