orangepi5
Standard support
Desktop
Armbian 26.5.1 Gnome
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.5.1 Minimal / IOT
Kernel: 6.1.115, Size: 290.2 MB, Release date: Jun 24, 2026
4K Video acceleration within Chromium works only in Jammy / Noble Gnome or KDE Neon desktop images with kernel 6.1.y
Enable AP6275P Wireless Module on Orange Pi 5:
Enable orangepi-5-ap6275p overlay from Hardware menu of armbian-config and reboot.
In order to run Kodi (sudo apt install kodi) with HW acceleration, you have to run kodi under gbm or wayland.
Armbian 24.11.1 Noble KDE Neon test report:
  • Flashed to SD card with USB imager
  • Boot ok, from sdcard, install to NVME and boot from
  • HDMI is ok, HDMI audio works
  • USB2 ports are ok
  • Gigabit Etherner is ok, troughput ~940Mbit/s
  • 4K video playback works in Chromium (accelerated)
  • Reboot and shutdown work as intended
Armbian 24.11.1 Bookworm minimal test report:
  • USB2 ports are ok
Build Date: Jun 24, 2026
Most stable mainline based kernel but not all features have been implemented yet.
Based on Rockchip BSP. This kernel is newer than the legacy kernel v5.10.y and works stable too.
Resolute Minimal / IOT SHA    ASC 315.6 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 309.3 MB
Resolute Minimal / IOT SHA    ASC 289.4 MB
Debian Testing (Sid) Kali Linux SHA    ASC 546 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 533.3 MB
Debian 13 (Trixie) OpenMediaVault SHA    ASC 404.8 MB
1000tx 16GB 1wire 4GB 64bit 8 core 8GB CAN UASP bluetooth docker eMMC i2c m2 mpci msata pci sata spi spi flash usb-c usb3 wifi RK3588 Rockchip
Debian 14 (Forky) Minimal / IOT rolling 6.1.115 SHA  ASC 293.7 MB
Resolute Gnome stable 6.1.115 SHA  ASC 956.7 MB
