Youyeetoo YY3588
Community maintained
Flashing instructions:
    1. Hold MASK button and power the device up to enter MASKROM mode
    2. You will need mini loader binary for this device.
    3. Follow instruction for flashing with RKdevtools: https://docs.armbian.com/User-Guide_Getting-Started/#rockchip
Rockchip RK3588
Build Date: Jun 24, 2026
Debian 14 (Forky) Minimal / IOT rolling 6.1.115 SHA  ASC 291.1 MB
Resolute Gnome stable 6.1.115 SHA  ASC 972.1 MB
